Neff S72M63x1gb/55 control module replaced but needs programming?
Our dishwasher stopped mid-cycle with no display and no response from buttons. Control module (power module) was found to have a failed component. Have fitted a replacement unit - EPG60613, 9000683387 - the same numbers as the failed unit and the machine now works but programmes take more than twice the time that they should, two of the programmes do not respond to their button and the last two menu options do not appear when cycling through them.
Should a module with the same EPG and 9000 numbers be fully compatible with this machine or would it still need to be programmed and if so, how?
  • Replies 0
  • Peter_S
