frontload washer leak from underneath Electrolux EIFLS60T1
Mark Franklin Rossow
leaks ~1/4 cup of slightly soapy water from front left corner
a small amount more drains down when not in use, after initial water wiped up
dry on other 3 sides, including at drain hose area
rubber seal seems good; drain holes in rubber are clear
water is Not coming down the front face
(also need to know how to take off the front sheet metal around the door)
bought 2016
  • Replies 1
  • Mark Franklin Rossow
  • MrApplianceMatt
The model number you posted doesn't come up in Sears. Double check the model number so we can help
