Manufacturer: Frigidaire
Type of Appliance: Freezer
Model Number: LFFH17F7HWB
I installed new  board  and now this is what it's doing.
Board set to -10F
Measured -13F
Board says " 92F High Temp"
Alarm is not beeping.   It should be!
Not sure about the beeping (maybe it doesn't been if it's too far out of range?), however there is a thermistor (297018400) that you should probably check.
Weirdly enough, it's between L1 coming off the power cord & pin 1 on the board. It's a red wire on pin 1.
Even better, it's not shown on the parts diagram and I have no idea where it's located or what the normal resistance is.
Sorry for the non-help help. 8-)
There's no service manual on Electrolux's site either. I just looked.
There's a tech sheet that should be in the machine somewhere, but I'll upload it here in case it's missing.
Edited by Terry Carmen
  • Thanks 1
I believe this service manual has information that applies to your model:
  • Thanks 1
