Manufacturer: Frigidaire
Type of Appliance: Freezer
Model Number: LFFH17F7HWB
I installed new  board  and now this is what it's doing.
Board set to -10F
Measured -13F
Board says " 92F High Temp"
Alarm is not beeping.   It should be!
Posted (edited)
Not sure about the beeping (maybe it doesn't been if it's too far out of range?), however there is a thermistor (297018400) that you should probably check.
Weirdly enough, it's between L1 coming off the power cord & pin 1 on the board. It's a red wire on pin 1.
Even better, it's not shown on the parts diagram and I have no idea where it's located or what the normal resistance is.
Sorry for the non-help help. 8-)
There's no service manual on Electrolux's site either. I just looked.
There's a tech sheet that should be in the machine somewhere, but I'll upload it here in case it's missing.
Edited by Terry Carmen
  • Thanks 1
I believe this service manual has information that applies to your model:
  • Thanks 1
