Frigidaire Model FFET1222QW fridge
The evaporator fan has stopped working in this fridge. The specs for the OEM part are 12V, 4W, 2100RPM. I have access to the same size fan by the same manufacturer as the broken fan; the new fan's specs are 12V, 4W, 2400RPM. Would there be any problem replacing the 2100RPM evaporator fan with the 2400RPM fan?
  • vee8power
  • KCTBURY
  • Diyrepair
part number 5304519506
use that part 5304519506 , not the ones off ebay or amazon... it never ends well trying to save a few bucks on a part. Faster airflow over the evap can cause havoc, and or leaks on some already cheap metal.
Did you make sure you have voltage to the fan motor?
You'll end up replacing the control in the fridge too .
