Dishwasher crashed, pump appears to be working, display shows :20 , but goes out if you push any other button. Close the door the pump starts and runs a few minutes then nothing
  • Gaston
  • Ian B
  • MrApplianceMatt
Posted Images
The error seems to be for a draining issue. If there are more error codes stored, you'll have to invoke the diagnostics laid out in the tech sheet to retrieve them.
THank you. I will look at the sheet.
If the drain pump does operate normally and there’s no water in the tub, you may have a faulty aqua sensor/pressure sensor. Untwist the filter and see if there’s any debris. Clean it out and may fix your problem. If not then I’d change the sensor If there’s no clog in the drain system and drain pump is running. 4573A574-C5AF-4751-B31A-3C74B8C8F1A2.thumb.png.ef16656790e57e9893f3ebb2a466f92d.png
