Manufacturer: Whirlpool
Model Number: 596.58647890
GGrrr
  • Flateline
  • Son of Samurai
  • Captain Dunsel
Uploading tech sheet.Waiting on approval.
Thank you.I replaced the the start components with a 3 n1 a month ago very dirty condenser.compessor and everything ran for a 3 weeks while she ordered new fridge.when the new one came they put this one in garage in three days stopped working (spare now) when I went over today compressor was Luke warm like 80 it's cold on garage.the bottoms of compesser more warm.compressor winding we're like 2 and ten ohms start and run to common and about 12 to each other.wich is good.for some reason the evaporator fan was not working.120 to ground but no common yellow wire.need to see if it goes to timer.the evaporator was cold so if the evaporator alone fix won't help so wondering if I could have bad points in timer to evaporator and compressor.compressor runs but not pushing refriderent.not ready to condemn until I see if both loads of interest run through timer.cold control will turn compressor on and off condenser fan to.when I shut off timer then tuned it on the compressor does not turn on right away but evaporator fan does.thanks for listening.
Edited by Flateline
Added
Here's Captain Dunsel's upload. @Flateline It would be best if you started a new topic in the Appliance Repair Tech Forum about the problem you're dealing with. This forum is just for manual requests.
