Have a GE profile fridge not cooling. Came across your video in inverter type compressor and had a question. I get 12 vdc out from the motherboard not 4-6 like you said in video. Tested three pins on compressor and all are 7 ohms. Do You think it’s the motherboard or inverter that is bad?
  • Replies 6
  • 16345Ed
    4
  • zornstar
Inverter...
Did you unplug connector at inverter to test input to inverter from main board? Or leave it plugged in?
I checked at motherboard and the harness at the inverter. Both 12vdc
Question is were connectors unplugged or plugged in when testing VDC?
I believe 12 VDC is possible if connector not plugged in.
Thanks  for your help. Harness was unplugged from inverter during both test I performed.
probably good voltage if connectors plugged in.
bad inverter
