Manufacturer: Kenmore
Type of Appliance: Stove
Model Number: 790.77453801
Going out to this call and would like any tech info I can get for a customer complaint  that is oven won't shut off even though the it says it's off. They have to unplug it to get it to stop.
  • Replies 4
  • AllStarBob
  • applianceman1
  • Captain Dunsel
  • Terry Carmen
applianceman1
You should have the tech sheet when you go over.
There could be a stuck relay on the board.
I had one the other day that was grounded and it kept the element on causing an F2 Error.
If the outlet is wired correctly, about the only thing that will cause that is a stuck relay in the control board. # 316557211
This looks like the tech sheet: http://www.youserguide.com/wiki/Electrolux_316519824-002 I can't find it here.
Also, the overlay for the control board is glued on and hard to get off without damage, so if you can get it, I'd bring both. That way if you destroy the original , you still have a good one.
Edited by Terry Carmen
If you go to the b2b site you will find that information. Here!
Thank you
