    • 26 April 2025 02:00 PM Until 03:00 PM
      When: Saturday, April 26 @10:00 AM Eastern Time.
Whirlpool WFW8410SW02 not spinning fast enough
This washer does not spin dry the clothes fast enough during a regular cycle. The spin speed says high. However, it does a good job if you put it drain/spin. Sounds like the mechanical parts are working fine, but possibly some problem in the electronic controls. What can I look at ( or replace ) to narrow down or fix this ?
  • gpontis
  • 16345Ed
  • Jimd2
Before assuming electronic issue, I would inspect pump impeller I would also ask what type and how much detergent you use.
Washer will not go full speed if it senses the load is out of ballance
