Manufacturer: Kenmore
Type of Appliance: Dryer
Model Number: 417.81102003
Need the service manual for dryer. It is showing CE error code and then shuts off.
You have go to the b2b site.
@Wendell BWhile you at the b2b site.Look at the owners manual and you will found this!
The Check Exhaust feature may alert you to performance characteristics that are indicative of poor airflow through your venting system. If such a situation occurs,
will be displayed alternately with the time remaining in the cycle. You should immediately unplug your dryer and inspect your venting system.
Thank you
