Manufacturer: GE
Type of Appliance: SXS Refrigerator
Model Number: CZS25TSEBFSS
I've found the mini manual here. It gives no info as to key dance accessing error codes, running loads etc.
What now?
  • Replies 6
  • Quick
  • Son of Samurai
  • Captain Dunsel
  • EthanRanft
Posted Images
Unfortunately, it looks like the mini manual is all that GE is giving us on this one. Anyone know of a manual that might apply to this model or a similar one?
Anyone? Where's old Lighthouse when you need him...
Give this one a try:
This diagnostic modes manual should help too.
Oh Yea. That's close. Thank you so much!
I'd kiss you right on the forehead but your ugly as your Daddy. Thanks. 😊
If this GE is capable of going into diagnostics it may be done like this?
MODES
Demo mode entry procedure:
Press any of the temperature adjustment buttons to wake the dispenser board. Press and
hold the FF Warmer + FZ Colder buttons for 3 seconds. A single beep will be heard when demo mode has been successfully entered. Demo mode can also be entered through service mode. Demo mode exit procedure: Unplug or cycle power to the refrigerator.
Service mode entry procedure: Press any of the temperature adjustment buttons to wake the dispenser board. Press and hold all 4 temperature adjustment buttons for 3 seconds. The display will flash “00 00” to indicate service mode has been entered successfully. Once in service mode the FZ display represents the tens digit and the FF display represents the ones digit. Colder (down) buttons decrease the digit. Warmer (up) buttons increase the digit. Pressing any button other than the temperature adjust buttons will enter the desired test. A test mode must be selected within 30 seconds or service mode will time out and the refrigerator will return to normal operation. Once a test mode is selected the test number will flash in the display
for 3 seconds to confirm the test has been entered. To exit a test press one of the four temperature adjust keys. To exit service mode select test 16. Service mode will automatically exit after 15 minutes of inactivity.
