Samsung refrigerator RF265AASH icemaker water level
The icemaker puts too much water in the tray making one solid ice cube.  How do you reduce the amount of water that flows into the icemaker tray?  Samsung told me to try reset button which did not help.  Next step to replace the icemaker which I did but it still allows too much water to entry the tray. I saw on your blog about the two water amounts.  You gave the code for the 95 cc fill, what is the code for the 85cc fill?
  • David Meeks
  • 16345Ed
 it's kind of complicated to make the adjustment, only 2 ice levels are available - 85cc fill and 95cc fill, Initially the unit comes set for the 85cc fill and would have needed to be increased to be on the high setting.
Press and hold "Freezer" button and "Power cool" (the middle button on left, and upper on right) - hold them simultaneously for 12 seconds, and the control will enter an adjustment mode. The displays on the left side will show a code, and the display on the right will show a reference or adjustment segment. You want the number on the right to display "2" (one of the r/h keys will cause the number to change), once it shows "2" - the work the l/h keys to make the left display number show "0". Once you have these numbers displayed, do not input anymore and 20 or 30 seconds later, the control will store the setting and go back to normal display mode.
1= 95cc
2= 85cc
I would also check to ensure ice maker is level. Problem could be water valve too...
Edited by 16345Ed
I will try it.  I was also considering water valve or water pressure issue.
