Washer Manual Request
David54
Manufacturer: Kenmore
Type of Appliance: Front Load Washer
Model Number: 796.41472210
Requesting a manual for this unit.  I'd like to put it into diagnostics to check components.
One of the complaints is the detergent does not get flushed out of the little cup in the dispenser. The hoses are all clear - I'm wondering about the inlet valve...  The other complaint was a leak.  Found a pin size hole in the plastic "Y" connector just past the cold valve - one tube does to the glass door inlet (where it puts water over the glass door).
  • David54
  • Captain Dunsel
