This washer has the following error codes:
NOTICE! A Problem has been deteced with this unit.
Main: MV 2.082
INVT: V01 11
Service Mode Diagnostics:
There is a problem with the touchscreen. Please check and replace if necessary.
The clutch is not mechanically engaging with the basket properly.
The motor is not rotating properly. Check and replace if necessary.
The basket is not slowing down properly. Check the brake (resistor) and motor for proper operation.
The inverter PCB has a history of not running properly.
The brake resistor fail.
I realize that if all 6 issues are unrelated and require their own replacement parts, then making such a repair isn't worth it. But if several of these may be resolved by replacing the motor, for example, then it may be. Any thoughts?
Thanks!
  • Replies 1
  • xman1x
  • 16345Ed
Did you run diagnostics or just pull errors?
