Samsung SW65V9W Toploader service manual request
bapselectrical
Manufacturer: Samsung
Type of Appliance: Washing machine top loader
Model Number: SW65V9W
Have you validated the model number at an online parts site like Repair Clinic? (yes or no): No
This is an overseas model washing machine. I am after the schematic.
Problem statement: Machine does not drain. No error codes
Tested drain pump ok
Tested pressure switch ok on fill cycle.
Tested socket voltage 238VAC (NZ) standard ok.
Cleared blockage in drain hose and tub to drain pump.
Observed impeller does not rotate.
Need the schematic to check how the drain pump gets line.
Any assistance would be great.
Cheers Neil.
  • Son of Samurai
  • bapselectrical
14 hours ago, bapselectrical said:
SW65V9W
That doesn't look like a complete model number -- do you have the full one?
bapselectrical
The full model number is SW65V9WIP/XSA.
Thanks, that looks to be the correct one. Unfortunately, it looks like Samsung doesn't have any tech info out on this model. That would be a first, in my experience, but I can't find anything.
Anyone else able to find anything on this one?
