    • 01 March 2025 03:00 PM Until 04:00 PM
      When: Saturday, March 1 @10:00 AM Eastern Time.
range frigidaire CPCS3085LFA error 32
Hi!. when i plug in the range now it just start beeping with the error 32
managed to find it's a 12v problem
it looks like it should be the relay board (Part #: 318388400)
was wondering if anybody has info how i can test that part for the 12v error before replacing
i also found out the 12v problem could come from another part. which is way more expensive ( part # : 318329620 )
thank you!
  • Replies 1
  • Vance R
  • draylen19
Looked up the tech sheet and service manual. Not a lot of information. Error 32 is "12v on the service to low" The relay board looks to be the power supply. AC in on connector p1 pin 1 and 4. DC is out on connector p3, but they don't list which pins are dc out and dc ground. Since there is only 3 wires you will have to make some measurement to find out which is which. My guess would there is 12v and 5v out and dc ground. If you have "good" dc voltage out you will have to trace it to the induction generator housing board to see if the voltage makes it to that board.  If you don't have "good" voltage, power down the unit and remove connector on p3 and recheck. If voltage comes up. It voltage comes up you'll have to do this procedure for each module until it comes up - you found your module. If it never comes up - it would be the power (relay) board.
