Calibrate Hotpoint oven
David54
Manufacturer: Hot Point
Type of Appliance: Range
Model Number: RB75DP1WH
Have you validated the model number at an online parts site like Repair Clinic? (yes or no): N/A
I would like to calibrate Oven temp on this older range. Would anyone have the manual or info for doing this?
 Thanks!
  • Replies 5
  • David54
  • Son of Samurai
  • Hiroshi
Posted Images
That model number doesn't seem to be complete -- can you double check it?
Are you using a quality mercury thermometer for temp tracking?
How much is it off by? Most controls wont adjust more than + or - 35
Just curious how you are chasing this symptom...
I'm using a digital meter with a K type thermocouple to do the temps. It's only off 15 degrees.
Son of Samurai - thanks for the manual!!
