Ge Range/Oven will not heat properly
GE JB690DN1WW oven chamber will not come to temp. Preheat set to 350 gets to roughly 250. broiler element is working ,lower element seems to not get to temp. Pies,casserole etc. burn on top and under cook on bottoms. Pies are raw on bottom etc.
oven temp sensor tested at room Temp. Ohmed at 1093 was told should be between 1000 and 1100. Ohmed bottom element got 22 was told I should have between 15 and 45
i obtained these reference numbers from different sources on the internet but all sites gave roughly the same data.
i am open to any suggestions as to what you think is going on,I am thinking possibly the control board but not sure and don’t want to throw parts at it if they aren’t what is needed.
Any help is greatly appreciated
KJR
  • Replies 4
  • princeal
  • 16345Ed
  • Vance R
Either control not sending power to element or bad element. Do you own and know how to use a multimeter?
Thanks for the reply .Yes I have a multimeter and semi know how to use it
Check voltage at the element, should be 220 volts ac.
Vance R I will definitely check it Thanks
