Manufacturer: GE
Type of Appliance: Dryer
Model Number: GTD65EBSJ3WS
Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): No
Hi everyone, I need a little help here!,
we have a dead unit, we are trying to figure out if it’s the main control board or the ui board!, we need to what’s the voltage that it’s supposed to come out from the main board to ui board to come on!, unit it’s not responding at any buttons press!
any help is appreciated!, thank you
  • mmelectronics1
  • Son of Samurai
Here you go:
thank you samurai, i saw the mini service tech, but i didn't see any information about voltage outputs ,to check if we are my 3-6 volts dc that feed the interface(ui)?, do you whats the voltage?, we didn' t get nothing from mainboard!
Unfortunately, from what I can tell, they're not giving the specs for your expected voltages. Your best bet in this case would be to simply replace both the UI and the main control.
