Manufacturer: Fisher paykel
Type of Appliance: Dishwasher
Model Number: Dd24aw8
Looking for service manual. None of the manuals that I located on the site work for placing this model unit into diagnostics mode. I have tried every key dance possible.
  • Replies 7
  • David C
    4
  • J5*
  • Son of Samurai
Posted Images
Yes phase 8 dishdrawer is a whole new kettle of fish with  completley diffferent controls , electronics  , diagnostics and fault cods
I finally figured out the key dance and then used phase 9 manual for tests. Key dance is Start /pause and immediately hold menu select 3 and .4th button
Edited by David C
For future reference, you should be able to use this manual to enter diagnostics.
That’s phase 6 which is completely different to 8 and 9
you can use that manual for 603 , 605 , phase 6 and 7 but need to be aware some of the fault codes are different between the different models but the diagnostic modes work the same
Yes, the key dance is definitely different.
Thanks for pointing that out, @J5* -- my mistake. This one should be correct for phase 8:
Great! Thank you!
