I have a refrigerator that was not cooling at all. I Inspected unit and found off displayed which means refrigerator is turned off. Put into diagnostics and turned back on no fans or compressor is running I inspected boards and found that no lights was displayed and heard the relays clocking rest and waited about 10 minutes and then board lights came on and compressor started up. Recommend replacing both boards due to intermittent issue. I installed DA92-00111B and DA41-00670C and now it does not work at all. Is there anything else I should check?
No errors in diagnostics? What testing did you do with your meter to determine boards needs replaced?
Samsungs can take quite a while to restart. This refrigerator simply might have been turned off by mistake.
  • Like 2
If the display indicated off all you have to do is turn it back "on".  The early model were just 2 keys pushed at the same time, most of the time they are mark with small words. The 2 keys are on left side of display.  Newer models have to push 3 keys at once.
 10 minute delay is normal after plugging in refrig.
