Dryer has power but will not start. I went to take the back off the unit to check the thermal fuse, however, even after removing all of the hex screws, the back won’t budge. Almost like it’s welded on. Can that happen over time?  The dryer is about 20 years old. No other problems recently besides this. Thanks.
  • Rob C
  • sh2sh2
  • MaxRepair
This dryer is serviced from the front
Thanks for the response. So I would remove the lower front panel, and that would allow me access to the thermal fuse?
If your dryer won't start it might be due to a blown thermal fuse which is there to protect the dryer from overheating. A common reason for this problem is a faulty start switch. Try starting the dryer and if it hums but won't start the switch is ok, but if there is no humming sound and the dryer won't start, it is most likely due to a faulty start switch. A door switch that prevents the dryer from starting if the door is open could also cause this problem.
Thermal Fuse: The thermal fuse protects the dryer from overheating. It is located on the blower housing or at the dryer's heat source. The fuse can be checked with a multimeter for continuity. Pro Tip: A blown thermal fuse could indicate that you may have a restricted exhaust vent. Check it for blockages.
Start Switch: If the start switch is defective the dryer won't work. You can test the start switch by trying to start the dryer. If the dryer “hums†but does not start the your start switch is OK. If there is no noise the problem may be the start switch. Test with a multimeter.
Door Switch: The door switch engages when you close your dryer's door and you should hear it click. It can be tested with a multimeter.
I found this at https://www.electrafixbc.ca/appliances/dryer.html
Check it out for more info on your dryer issue.
