Dryer with compressor inside
Alfredo Dacanay
Whirlpool dryer, model number WHD560CHW0, looks like compressor inside and condenser coil, how is this thing work?
  • Replies 4
  • Alfredo Dacanay
  • Vance R
Heat pump dryer.  Same as a window AC, they just use the condenser heat to dry clothes.
Alfredo Dacanay
Is the dryer get hot like the normal dryer?
Alfredo Dacanay
I can hear the compressor runs but still not getting hot inside, will it be no freon issue?
It should get very warm and the time will be a bit longer than a normal dryer. If you have no heat that would mean the backup heaters aren't working as well. Check the lint screen and venting.
