Frigidaire Laundry Center-Stackable washer-dryer issues
Model Number FFLG4033QT0
I replaced the washer control board and lid lock switch.
The washer fills, agitates, then gets stuck...and beeps 3 times twice.  I am not sure what is going on.  Any help appreciated.  Thank you/
  • Replies 4
  • 16345Ed
  • Rmeinholz
  • isaac
  • AWSHandy
So it doesn’t drain?
  • 3 weeks later...
I'm having the same issue. I'm unable to enter diagnostic and tried multiple times to do so. Now it wont do anything no water in it and the lid is locked. I've tried the lock assembly and the UI to no avail. I've been struggling with this machine for awhile now. I've been told it would just beep randomly at them and now totally dead.
Edited by Rmeinholz
Forgot M# FFLE4033QW0
  • 10 months later...
Hey Guys any resultion?
I am having similar issue,  not sure if its the same problem,  basically it wont spin out,  tested unit on rinse and spin since theres no just spin and spend more the 30 minutes trying to put into service mode unsuccessfully,  any way after rinse it starts slow spin then starts filling again,  it does this 3 time and then just finishes cycle without ever going to high spin,  so i know it is supposedly an unbalanced load,  (this happed with or without any clothing in the unit,  since i can confirm any err i am not sure where the issue is,  sound to me like a bad motor control but i cant be sure,
Especially since in rinse i can hear niises i think of agitation but nothing moves,  but when i paused it and restarted it engaged
Here is a link to it making the noise in rinse (agitate? )
 anyone with any real experience with this units?
Model # FFLG4033QT0
  • 5 months later...
Most likely the faulty water level or temp switch. They are actually the same switch so you can flip them and see if that changes the symptoms. Most common part number for the selector switch is 137052500
