Manufacturer: LG
Type of Appliance: Gas Range
Model Number: LDG4313ST/00
Need to remove cook top to replace igniters
  • Replies 5
  • Son of Samurai
  • TurtleRock
  • Captain Dunsel
  • Terry Carmen
Calling out @Captain Dunsel on this -- he often has access to LG manuals.
Looks like it uses the same manual as I just uploaded for @Johnny B. Good
Awesome, thanks!
Thank again Guys
If you haven't done one before and the customer has had it for a while, you may want to warn them that the repair cost may have to include some or all of the surface burner heads (the things the orifices screw into).
They're some sort of aluminum and the screws frequently seize of up and sometimes the screws snap off instead of unscrewing. Once this happens, the burner head needs to be replaced.
Everything might go just fine for you, it's just something you should know before you start snapping off screw heads. 8-)
Terry
