Manufacturer: Samsung
Model Number: RB195ABBP/XAA
Can't seem to find parts for RB195ABBP/XAA. So many different variations of this model not sure which parts are accurate. Thank you!
  • Replies 6
  • tonyf7
    4
  • tstarkey
Whats the serial number of the unit and what parts do you need and I will look them up?
Thanks for your help!
Edited by tonyf7
Serial# is A07142BSC00110P and the parts I need are:
1. Main control board
2. Freezer temperature sensor
3. Ice maker
4. Control panel PCB
Thank you!
(Reposted because I forgot to quote)
1. Main control board = DA41-00554B
2. Freezer temperature sensor = DA32-10105R I think its this one it doesn't actually show one, but they are pretty all the same other than the plugs
3. Ice maker = DA97-05037D
4. Control panel PCB = DA41-00264G this is the only board I can find in that cover, this is the strangest model I have ever looked at that Samsung makes, I assume its really old.
Thank you!
Yep! Pretty old it seems! Both control board are NLA.
Samsung showed NLA also
