A few months ago I installed control board part #WPW10624574 on a Kitchenaid french door KRMF706ESS00. That restored power and unit worked fine till the other day customer said same thing no power/no lights. I had him do a hard reset and and its been working fine for a few days.  he doesn't recall any power surges recently.
Could he have a bad receptacle? He wants me to come out and put a surge protector on it, so I will check it then.
Any surge protectors you recommend?
Also, I didn't see any error codes but I wasnt able to find a tech sheet to get in and possibly check either.
Jared
I am having the exact issue on same model , it was like no power to the refrigerator ,but 120v to the power board unplug it and plugged it back after 1 minute ,came back on with out error other that lost power indicator
the customer said she turned off the breaker to the  refrigerator  4 to 6 months ago for the same problem
after reading your post I'm hesitant to replace the control board. they did have people doing work at the house ,could voltage drop trigger this kind of problem?
kurt
  • 4 months later...
I know it's been a while, but I just wanted to add that I never got called back on the call (it was warranty) so I'm not sure the outcome. The customer said he was going to pick up a surge protector,  but he also said if it acted up again it was going to the curb. So this one remains a mystery...
  • 3 months later...
I am posting here because I have a call on a 3-1/2 year old Kitchen Aid refrigerator that has been beeping and sending a PO code all night long.  Any ideas?  I have read this unit has an inverter compressor and it could be not cooling properly.  However the customer seems to think it’s cooling fine.  He unplugged it for 6 hours last night.  Woke up, plugged it in and it is still saying PO.  I guess I will check it out.  Got to love these newer whirlpool boxes.  Ugh.
This sounds like the board in the drawer is full of water,  check under that board for water/corrosion
It’s wasn’t that problem.  The freezer wasn’t cooling properly because it had a defrost problem that stopped the freezer fan motor.  I replaced the defrost sensor.
  • Thanks 1
The first thing I looked for.  Not this one. 5 door.  Wire connection on the left door.
  • 3 weeks later...
Just went to one of these today.
Runs and cools and then just blacks out- comes back with PO
Given the posts above- seems to be somewhat common eh?
Only if they spill something on the deli drawer ui.
  • 2 months later...
Denver Todd
Isaac, are you referring to item 41 on page 8 of parts list?
Edited by Denver Todd
Yes , believe @isaacis refering the ui of the deli drawer. Common issue.
Denver Todd
What are the symptoms? I have a buddy who had an order to work on a machine that would go dead intermittently, like once every six months, and unplugging and replugging brought it back to life. He didn't know what direction to take. But what is the fix, to just change out the crisper UI board?
There are a buch of symptoms from complete shutdown to weird issues happening intermiitently. Remove the deli UI board to inspect. It may have water/liquid in the tray as well as corrosion. The corroision can follow the wires into the drawer. The wire harness from the drawer to the side part liner travels along the drawer rails and can get pinches and breaks. The dc loading could possibly damage the main, power supply boards. Hope your friend gets off with an easy fix.
  • 1 month later...
I have a KRMF706ESS1 with this same PO intermittent error.
Customer first notice Freezer Evap Fan motor grinding on Ice. I speculate ice build-up due to Defrost Sensor position (WPL has Bulletin on it), one of the 5 door/drawer gaskets not sealing, and/or dirty condenser on a fridge that requires vasoline to squeeze it into the surrounding cabinet, (not external heat exhaustion).
FC evap fan no longer running.
Condensation now dripping from Left Fresh food Door onto deli User Interface board. I do not see any broken wires in or around that drawer. Nor on the left door.
I try to run Service Tests but the machine turns off and on every time.
Does this theory make sense to you:
Defrost sensor position lead to ice-build up and stopped movement of Evap fan motor in freezer.
This caused excessive moisture around fridge door seal to drip onto Left Deli drawer UI, possibly arcing or causing electrical damage to Main PCB which is now intermittently dropping voltage.
Bad: Defrost Sensor, UI on deli drawer, and Main PCB.
I'm not a Parts Changing Monkey, but I know that I don't know the theory of operation for this model. Isn't the Main PCB responsible for Power Distribution to all other components and PCB/UI on this model. I'll attach the Service Man.
Thinking 2 out of the 3 - thermistor replacement as per service bulletin, disconnect ui to check loading on main board.
Replace ui and if needed the main board.
Updated service pointer for evap issue is w11092686.
Edited by Vance R
spelling
How would the deli UI board cause intermittent power loss?
Loads down the DC supplies, causes all kinds of odd issues.
The low voltage power supply is "just big enough" to handle normal operation. If something uses too much, it drops the voltage causing weirdness and/or will completely die turning off everything.
Edited by Terry Carmen
