Maytag Bravos mvwb850wl2 still very noisy after bearing replacement
Hi!
Model Number: Maytag Bravos mvwb850wl2
Brand: Maytag
Age: 6-10 years
2 weeks ago I replaced my washer machine bearings. I tested it with a heavy load and it looked perfect. I ask my wife a couple of time since then and she said it looked okay.
But, today, I heard that same (or very similar) very noisy sounds when spinning at high speed. Inside the washer was many bed sheets so it was a heavy load. When I replaced the bearings I saw that rotor internal spline/gear were pretty used. Same with the agitator.
Here is a video with sound from my cellphone. I slided it under the washer.
Thanks for your help!!
https://youtu.be/TtLWdooXlsU
Jean-Philippe Guérin
  • 3 weeks later...
  • LearningTech
  • EthanRanft
  • JPGraphX
Sounds like a dry bearing.
 Did you use whilpool bearing or a cheap ebay one?
did you use the tool or otherwise press them in?
option 1 take it all apart and put together again tight
option 2 let it run and its noisey and may or may not lead to premature failure
You get what you pay for in these cases
