JennAir JJW9827DDS Double oven: Lower oven unresponsive
Greetings!
Our lower oven does not respond to anything on the control panel. The upper one does. Have done power off overnight. Still only beeps when touching anything except when poking around a "feature not available Press Help" appeared and also in yellow "9d22" next to the clock. It seems to be an electric range error code?
On repowering, the display says something about unlocking the oven door. The lock hook is rather loose on the lower oven compared to the upper one...perhaps that is causing the issue? I have swapped out the entire control assembly (entire setup held in place by the four screws) expecting the problem to have been in the control panel...same problem so the original panel is okay.
Another post suggested an open in the heating element could cause this. Do you think my next step should be to swap the heating element (assuming the lower one not the broil one) or try the lock hook mechanism? I may have the parts to try from a salvaged oven with the same model number...
On a very limited budget and any and all help will be greatly appreciated! Many thanks in advance!
  • mbed
  • vee8power
On 3/12/2020 at 9:22 AM, mbed said:
Greetings!
a bump
Try cleaning the ribbon cable with a pencil eraser.
  • 8 months later...
greetings, all!
in case it helps someone...I finally resolved the lower oven issue. It seems the locking door latch has a cutout switch of sorts. I was wiggling it throughout its range of motion while trying the controls for the lower oven and it finally worked once it was placed in a certain position...thanks!
