GE Hotpoint CTX14CPGRWH Water Leak - Seeking Alternate Solution
I have water collecting/icing up on the bottom shelf of the fridge (freezer on top, fridge on bottom). I
1. snaked the drain tube running from the freezer down to the drain pan
2. replaced the door gasket, using gentle heat on the gasket to ensure a tight fit
I'm still seeing water collect though.  Any ideas of what else it could be?
Unit level? Or rather tipped 5-10* back?
 Is the p trap or j trap present at the back?
is the drain iceing up?
is there a heat strap present on the heater?
