110.82874820 kenmore washer basket cockeyed
BradleyHolcomb
40ish (?) year old kenmore washer basket is cockeyed and bangs during spin, also some water ends up outside basket during fill, what should I look for first? I have done repairs to this many times so I know how to open it up, just wondering what is the likely cause so I can focus my time. TIA
BradleyHolcomb
did some more googling, likely an issue with counterbalance spring? if it's in the left rear that would explain the basket cockeyed to the forward/right
Yep. Depending on condition I’ve seen place On frame where springs attach rusted out. You’ll need to inspect all those springs. I think 3 of them.
  • Like 2
you may have to drill a new hole in the frame just to the side of the old one .  and install new counterbalance spring,  good ol' washer
  • Like 3
  • 3 months later...
HillBilly1960
I have a customers Kenmore 110.5072011, it works great durung diagnostics but do a load of clothes, when it goes to spin it bangs violently as if it can not balance the load. Help... all tension springs and bolts are solid, intact. I am doing a test laod right now after adjusting the legs and leveling. I hope it fixes it. any other things I might be missing?
  • 3 weeks later...
BradleyHolcomb
Sorry I forgot to reply to this. It was the counterbalance spring, it was broken, hole was intact. $5 for a new spring at at local mom-n-pop appliance repair and I'm back in business. Still going strong, they don't make them like they used to!
