Manufacturer: Frigidaire
Model Number: FGRU19F6QFC
Hello, can you help find the tech sheet for this Frigidaire FGRU19F6QFC please? I tried searching on the frigidaire support website but it says document not found. Thank you
Believe this should be close:
Thank you, Vance!!
@Vance R do you by any chance know if this model has a diagnostic/service mode, and if so how would I get into it? On the data sheet it doesn’t mention about it. Thanks again
All that i remember is in the middle of first page is the steps to force defrost.
That’s correct. Thanks again
