oldtrooper74
Manufacturer: Maytag
Type of Appliance: three door bottoom freezer
Model Number: gx5fhtxvy04
Replaced interior bulbs on control board due to overheated sockets. Later the left bulb burned out and water dispenser works only with the freezer door switch. Also the refrigerator light will not work alone need both to work. Received the jazz board schematic from Capt. Dunsel Which was very nice but the image was blurred so not to readable. Would like clearer image to retrace the jazz circuitry and fix this machine. Thank you. Oldtrooper74.
  • Replies 4
  • WOOKIE
  • oldtrooper74
  • Captain Dunsel
Posted Images
Try GX5f* in the manual search.  It will bring up the tech sheet with the  schematic and wiring diagram.  The freezer light get" it power thru a relay.  The water dispenser gets it neutral on the same wire to the jazz board that the lights do.
Edited by WOOKIE
Not relay --- door switch.
The tech sheet is within this bundle! GX5FHTXVY04 Tech Sheet - W10308613
I don't know if this will help you or confuse you.  I made this when I was studying the refrigerator.  If it help's to trace the circuits use it  if not, trash it.
oldtrooper74
Gentleman all!!! Thank you very much for your responses. I feel that as I read all of this information that if I can't find the answer in there then maybe I am in the wrong line of work. Truly thank all of you for your interest in helping. Really appreciated.
