Manufacturer: Maytag
Type of Appliance: Washer
Model Number: LAT8816AAE
I need the schematic and tech sheet.
Couldn't find tech sheet. Couple of web sites for parts had wiring diagram.  If you use lat88* couple of service manual come upj just don'y have your model wire diagram. Copied this from one of the web sites for wiring. Hopefully one of the brethren can come up with correct tech sheet. This should get you started.
  • Thanks 1
Go to servicematters Limited Access. https://servicematters.com/en_US
Put your model number in where it says part number and then click on Parts list and within that is a wiring diagram. Its Free and and something to remember for certain things!
  • Thanks 1
Thank you both for your help.  I will keep that site for the future.
