Customer complait Gas smell from oven when in use service manual request
Manufacturer: frigidare
Type of Appliance: gas stove
Model Number: FGGF3030PBA
Customer complait gas smell comes from the bottom of oven when its in use,   anyone familiar with a possible solution ,My first guest is possibly a bad regulator or a leaking fitting, the unit is about 10yrs old
This service manual looks like it applies:
Tech sheet, available once approved:
FWIW, check for a weak bake ignitor when getting gas smell while baking
Edited by EthanRanft
  • Thanks 1
thanks a lot Sir What dose FWIW stand for?
It stands for "For what it's worth".
  • Thanks 1
thanks sam
RF26HFENDSR-AA Sampson refrigerator leaking water under the crisper drawer.  I had a service call 4 days ago on this and when i showed up the refrigerator was unplugged  when i arrived  i couldn't verify the issue that they where having i installed a new drain kit and blew the drain out hoping that would work .they just called back and reported the same issue , Now there is condensation developing on the back wall  any suggestions about what else it could be?
@nutdriver We try to keep tech help questions out of the Manual Requests forum -- it keeps things much more organized and readable. Could you post your question as a new topic in the Appliance Repair Tech Help forum? If needed, you can always post a link to this topic from your new topic.
  • Thanks 1
Guest
This topic is now closed to further replies.
