Samsung Dryer quit heating, found bad high limit and the old element looked marginally suspect, so I put new element and replaced both the operation thermostat and the hi limit fuse on, found no vent restrictions, put back together, and tested without clothes and with no vent, unit worked great for one cycle, then when it was time to start the second cycle it wasn’t heating again, I took it back apart and the brand new high limit was blown again, any ideas?
  • lvasquez11
  • 16345Ed
  • The03wall
Plugged exhaust vent or plugged lint screen causing poor air flow.
You need new motor assembly.  Bad contacts within motor switch.
Model#
