Tappan 11-1553-3070 Electric Oven Wiring HELP
JoeyInGeorgia
Hi All,
I have a Tappan electric oven (Model 11-1553-3070) where I accidentally pulled the power wire plugs loose and need help as to where they plug back up.  The wires I need to  connect are the Red, Black, White, and Green.  The green has a ring terminal and is grounded to the frame.  The white is ground, red to black is 220 volts and red to white is 120 volts and black to white is 120 volts.  The picture shows the thermostat on the left and clock on the right.  Second from left is the control and left of the clock is the on/off light switch and oven on light.  So the wires that I need to know where to connect are the red, black, and white.  There is a spare terminal on the thermostat, one on the selector switch and two on the back of the clock.  Any help will be appreciated.  Thanks much.
Well, I was unable to attach the picture I took so I hope the descriptions help.
Joey
  • Replies 1
  • ECtoFix
  • JoeyInGeorgia
