Bosch Dishwasher [SMU69U85AU/93] - Error 04
Ricardo Lottermann
Hi there, I have a Bosh Dishwasher model SMU69U85AU/93 which I am getting an Error 4 after
it does all the cycle, in the last 1 minute it gives me this error, I was able to run Diagnostic Mode on it and the error always happens
on S11 (whatever that means), does anyone have any idea of what might be wrong with it? This started happening after my wife tried washing using regular dish soap
but it didn't run the whole cycle with it (10 minutes approx), she saw the foam coming outside and turned it off, could this problem be related to that? Is there any chance
this could be fixed ?
I already tried:
- Resetting
- Turning it off from power and leaving it a long time
- There is no clog
Thanks in advance, any help is appreciated!
  • Replies 1
  • Budget Appliance Repair
  • Ricardo Lottermann
I'm not sure what the errors are that you are getting mean but the regular dish detergent could be causing your problem because of all the suds.
To clear the suds put two cap fulls of any vegetable oil in the dishwasher and let it fill with water and run for about 2 or 3 minutes then do a cancel/drain cycle - that should clear all the suds out.
If you are able to do the above, then try to run a regular cycle and see if it works.
