Manufacturer: Sears/LG
Type of Appliance: Front load washer
Model Number: 796.41472210
Need tech sheet for this or comparable LG model. This unit has both a drain and recirculating pump. I have manual MFL68588925. It was for a Sears model number that appears to be for a different series (Kenmore LG 796.4130#). If that will work, I’m good to go. I just want to make sure the diagnostics are the same before I look at unit. Otherwise I need the correct tech sheet/manual. Thanks
  • Replies 5
  • Vince Neibert
    4
  • Captain Dunsel
Posted Images
Here you go!
  • Thanks 1
Holy cow! I confess I had my doubts as to whether anyone could come up with the exact manual. I was just hoping for one that would work. Thanks a lot! @Captain Dunsel
Hey, my friend @Captain Dunsel  -I have a question for you. How did you transfer that block of info from another post to the one you gave me?
One way was I already had that one in my google drive! On some of this Kenmore LG stuff if you go to the Sears site and if your lucky you may find the washer service manual number like this.MFL67307912 on the site and then you come back here and look it up.
