    • 15 March 2025 02:00 PM Until 03:00 PM
      5
      When: Saturday, March 15 @10:00 AM Eastern Time.
Manufacturer: frigidaire/electrolux
Type of Appliance: washer frontload
Model Number: EFLS210TIW00
No tech sheet with the machine   :(    I have tried researching this in the downloads section but The only thing I can find in this site that is closely related to this compact model  was a sears # search of 417.41942710  That actually didnt give me what I needed.   The b2b frigidaire site only has the user manual, the wiring diagrame , and the installation procedure but there nothing on servicing this model in diagnostics or any type of servicing procedure to follow , that I can see .  I believe its a real small tech sheet with not alot of procedural diagnostic procedures but there is one out there.  I remember running into one of these a while back.  Any help with getting this technical sheet would be appreciated.    Thanks Darren
Looks like it’s similar to this?
I know the both those models take the same wiring diagram and that service manual seems to me does not tell you how to get into the diagnostic mode at least as far as I can tell!
Thanks Captain.   This should suffice !   I appreciate that catch.  My original search on the site did not bring this up since I had not a Letter ( i )  between the E and the F on my models sticker.   I am not quite sure what the  ( i )  stands for ?  but either way thanks for finding a similiar technical service manual.   The control panels are the same so i will assume the information in this service manual will work just fine.  The trouble shooting section based on alarm codes is quite extensive in this manual. Which is more than I have. The trouble shooting section explains quite a lot . Thats a plus. There are a lot of specifications in that part of the service manual.  It's strange that they are not supplying  any manual  diagnostic testing procedures ?   The service manual referances running the diagnostic cycle test for certain components here and there in the Trouble shooting based on alarm codes section too.    I'm thinking maybe their referanceing run the diagnostic cycle test to be just test the parts in the cycle selections on the control panel ?? don't know.  I do remember a few years back that the washer the same as in my post but a different customer, Had a small tech sheet with it Taped on top of the detergent dispenser. thinking back I thought for sure it had some manual diagnostic testing in that tech sheet but It was so long ago I dont quite remember. It just may have not had anything in it for a manual or automatic diagnostic test.  Thanks so much brother for the help. I hope to be able to return the favor in the future.  :)
Edited by darren412
