TMTRAINING
I have a "tE" error caused by a disconnected/broken/failed (blue) wire at the plug which connects to the THERMISTOR at the front/bottom of my LG washer tub.  I can't find a place to buy the wire harness. Can I fix the connector? Or is there a place to buy the wire harness
  • ECtoFix
  • TMTRAINING
Providing a model number would help someone help you.
Nonetheless, if you go to this link and enter your machine's model number, the correct wiring harness should be listed:
https://www.repairclinic.com/
I happened to do a general search for a LG clothes washer and found 57 different ones listed.
57 wire harnesses, that is.
