Manufacturer: KitchenAid
Type of Appliance: Built in refrigerator
Model Number: KSSC42QTS00
Need job aid to figure out how to remove the water and ice dispenser. Problem with the unit is it won't dispense water.
The closest job aid I can find is this one. It doesn't apply to your specific model, but it might be close enough to help you out.
T
This is the correct service manual for that job. You must remove the stainless panels from the door to get to it.
