AFI2538AEB4 not making ice, replaced ice maker still no ice...
CyberCode26
Hello, I could use some assistance. I have a Whirlpool AFI2538AEB4 refrigerator that is not making ice. I did some research online, and the most common problem is that the ice maker motor that turns the auger fails, and need replacing. Or the timer, etc. I just replaced the entire assembly, as it wasn't much more. No muss, no fuss.
New ice maker does not make ice. I'm not sure what else to do, as I have no schematic. I'm capable of troubleshooting, just could use some direction. I see on the timer there are different points to test, and I get 120v on the L and N when the switch is on and the doors are closed. But, still no auger movement, no ice making. (Auger being the white plastic piece that ejects the cubes from the tray). If I press door button for ice, I get the solenoid pop to open door, and the stainless feed auger moves. Water through the door works, so I know I have no flow issues (valve could be bad I understand, but again, ejection auger isn't moving at all). If any one has any info, I would be greatly appreciative of sharing!
Thank you!
  • Replies 0
  • CyberCode26
