My fridgidaire gallery stopped making ice 3 weeks ago. The air and water filters are only 6 weeks old. I took the ice maker apart and found the ice mold cracked and mold thermostat dangling and damaged so I replaced the whole assembly, no ice. I ran the ice maker diagnostic tests, the fan works fine but it wouldn’t fill with water, the hose wasn’t frozen so I replaced the valve assembly. Now I can get it to fill but it wonÂ’t dump the ice. Then I figured the heater must not be cycling so I replaced the defrost thermostat and defrost heater. Still no ice. The Temperatures are set at 0 freezer 35 fridge. I need some help here, I’m out of ideas. Thanks
  • Replies 6
  • igloo
  • Matt410
  • Wx4usa
  • kokomo
Posted Images
There is a known issue with this model where the fill tube for the ice maker freezes. There is a service kit for it. Check with your local parts distributor and they should be able to help you get the service kit.
Cool but the fill tube isn’t frozen. I can get it to fill through the diagnostic mode test 55
What is the actual temperature of ice maker?
  • 2 months later...
Wx4usa I have the same issue, same model # how to get I/M temperature. I have water from fill tube on same test 55.
  • 3 years later...
Do you or does anyone else have a link for this bulletin please?
Maybe this? It's in the 5995612875 for 2012 service updates manual
