I recently repair a older side by side Kenmore fridge that there coils had frozen over on. Checked the defrost timer. Set it one click away from cycling back on and within a few minutes the cycle started. Turned the thermostat to off and that was turned the cycle off. Found heater broken. Heater came as assembly with defrost thermostat. About 1 month later the problem is back.
If you replaced thermostat and heater. The timer is only thing left. Unless you broke heater or incorrectly installed thermostat.
