Kenmore 253.60082411 Refrigerator/Freezer defrost problem
I have a Kenmore 253.60082411 refrigerator/freezer. I am having the following problem with this unit. Recently, I noticed frost appearing on the inside of the freezer, freezer burn on some food items and the refrigerator not nearly cold enough. The freezer was very cold. I put my hand in the back and couldn't feel much cold air coming through the vents. I emptied both the freezer and refrigerator, removed the back panel of the freezer and noticed that the hole between the refrigerator and freezer was clogged with ice. I defrosted the unit, removed the ice and everything was fine for a few days. Now, I notice the refrigerator getting warm again and frost appearing in the freezer. The coils on the inside of the freezer have a lot of white frost on them and the hole is clogged again.
This unit has some self-test ability. I was able to trigger a defrost cycle by pressing the door button 5 times. This caused a lot of water to dump into the fresh compartment.
What is likely the problem and what would be the proper way to confirm the part that is defective?
  • Replies 5
  • Vance R
  • jhmod
Check to make sure the defrost drain is clear. Next check both door gaskets for proper sealing.
Did both of those. I assume the extra water spill was due to the fact that the coils were completely frozen over. I'm less concerned with the spill than I am with the fact that I have to trigger the defroster manually. That means the heating element is fine. I'm wondering what else could be defective and how I would troubleshoot that part(s).
Check the defrost thermistor resistance using the specs from the tech sheet.  If that is good it is more than likely the board.
Is that the same as the bimetal thermostat? When I search for "Thermistor" in parts, I find nothing.
At sears parts it is item 21a in system parts.
