Ice cream is melting in the freezer side again.  Got 32F temperature.  Suspecting is one of the sensors or freezed evaporator.
Does anyone have the tech manual?  I probably need to test the main board in the back.
Thanks!
  • Replies 4
  • edcmaak11
    4
  • 16345Ed
Just opened the back by the evaporator that 1/4 frost on the bottom and top was clear.  I opened the back by the condenser. Condenser was super hot to the touch, the coil was dirty and the fan was blowing. It has a burning smell.  I cleaned the coil with vacuum and spray water.  Now condenser is not as hot now but evaporator is still 1/4 frost on bottom.
Surprisingly when I was cleaning the coil at condenser that the heat kicked in for about 10 mins.
Sealed system issue. Leak or restricted.
BTW, technical documents for professional paid members only.
Edited by 16345Ed
Close system is a pain in the neck. Don’t know it will fix this issue.  Guess going to get a new frig.  Damn, servicing since after 1 year warranty.  Changed heater twice, 1 of the the white sensor once.
