My dryer was making terrible noises.  To make a long story short, I took it apart and replaced the wheels and new felt around the drum.  I put it back together.  I was really proud that I was able to ifx it and get back to work BUT now there is no heat which wasn't a problem before I took it apart.  ANy ideas?  Electric not Gas.
Thank you!
Bryan
  • emo2eq
  • john63
Most likely a wire on the thermostat was accidently disconnected.
Mounted on the heater housing
Thank you.  The white wire on the high limit thermostat had broken loose.  It looks like they were soldered originally.  I had to solder the wire back on.  Thank you the help I have a quite dryer with HEAT!!!
