lghk2336tf0 Evap fan/control board issue
CharlieArlieO
Hey y’all put a new fan in this Frigidaire gallery lghk2336tf0 didn’t fix it so I put a new board in anit worked for 3 months now it’s doing the same thing have any of y’all run into this issue with with this machine? It’s a 12v dc fan with a wire harness I’ve never seen before with like 6 wires lol or does anyone know if I can put it in diagnostics I can’t locate a tech sheet any info would be greatly appreciated!! Thanks!!
  • Replies 4
  • 16345Ed
  • CharlieArlieO
Tell us what was wrong initially. And explain the testing you did.
CharlieArlieO
Ok well initially the evap fan just wasn’t blowing, compressor and condenser fan working coils very cold end to end so put new fan in still nothing, all the cooling, fan, and adc are controlled by the main board replaced it with new board worked good for 3 months now same symptoms I have a feeling it’s the board again and couldn’t find a tech sheet to see hit to do a manual test or run diagnostics or if it’s worth fixing. Lol I really appreciate your response thank you!!
Has to be a sensor/thermistor of some sort sending temp info to board. Has that been tested?
Are you getting an error code?
Any ice behind back wall of freezer coming from ice maker fill tube area?
